Problem with slideshow
Hello
I have a problem with the slide show that I put in position top-a on the template rooms. This one does not take into account the fact that my images are 500 px high, and therefore my block of content is too sudden. How can I force the slider to respect this size.
Thank you for your help
by Fred-Ufcv
The height of the image is not important, please do not set the height of the image at the module settings.
In responsive views the image will always be scaled!! It makes no sense to limit the height, becasue then the ratio is wrong!
Hello thank for your answer. So i can't put a size for the slide, that's true ?
by Fred-Ufcv
Yes... the images will be scaled always > responsive
The following user(s) said Thank You: Fred-Ufcv
