3-level menu
3-level menu was created by francesco@fassamedia.com
Posted 8 years 6 months ago #18886
I want to create a new menu item in the third level, in the vertical menu. Why does the third level item appear together with the second level items and not in a new column?
Thank you for any help.
Francesco
Replied by joomlaplates on topic 3-level menu
Posted 8 years 6 months ago #18913
the third level menu is not supported because of the touch screen events.
But you can try to add this code to your css/custom.css
.uk-nav-navbar > .uk-parent > .uk-nav-sub { display: none; }
.uk-nav-navbar > .uk-parent > a:after {
content: "\f107";
font-family: "FontAwesome";
display: block;
float: right;
.uk-nav-navbar > .uk-parent:hover > .uk-nav-sub {
display: block;
background: none repeat scroll 0 0 padding-box #fff;
border: 1px solid rgba(0, 0, 0, 0.12);
box-shadow: 0 6px 8px rgba(0, 0, 0, 0.3);
width: 200px;
margin-top: -5px;
padding: 15px;
position: absolute;
left: 150px;
Now you should have a third level menu, but need to customize the css parameters maybe.
The following user(s) said Thank You: francesco@fassamedia.com
Replied by francesco@fassamedia.com on topic 3-level menu
Posted 8 years 6 months ago #18923
Thank you very much for the tips.
Can I ask if there are any contraindications for a third level menu in this template?
Thank you for all.
Francesco
Posted 8 years 6 months ago #18927
Isnt working?
Or what do you mean?
Posted 8 years 6 months ago #18940
If the third level for the menu is not foreseen, maybe there is a reason. Maybe it does not work properly?
Posted 8 years 6 months ago #18942
Did you add the code above?
I have checked that and it works, looks like the image
Attachment Screenshot_8-2-3-4.jpg not found
