Articles not showing
Is it possible to use articles in 1Page template or it is restricted to modules ?
by a.spathis
The following user(s) said Thank You: Sebastian123
- Sebastian123
I have the same problem. As a joomla newbie I could only find the blog article. All other content of the page is not able to edit.
Thanks for help!
Thanks for help!
by Sebastian123
you can use Joomla artiles too, but then its no more a onepage design!
Thanks for the reply, I quite understand the difference but for example on the blog page sample articles there are buttons named "more", I can use those buttons with external URLs, it is possible to use them in order to load a joomla article and how ? I have tried with article's joomla URL but it's now working properly !
Can you please guide me where to find instructions on the documentation in order to use joomla articles ?
Last Edit:8 years 7 months ago
by a.spathis
Last edit: 8 years 7 months ago by a.spathis.
Please check if the system output is not disbaled.
Template Settings > Layouts > System Output
Last edit: 8 years 7 months ago by joomlaplates.
It's not disabled on my JP-1 Page template but I can't access any article. A test arcticle can be found at
www.cultural-representation.com/new3/ind...e&layout=edit&id=56§
by a.spathis
