space between modules
I need to reduce the space between the menu and the content section, as you can see in my screenshot. The problem is only with the smartphone view. Can you help me?
Thanks!
Thanks!
by griffin
[secret]
www.lucasalvadoriviolin.it
[/secret]
thanks!
thanks!
by griffin
Try this code below and add the css style to your css/custom.css
@media screen and (min-width: 768px) {
.main-outer {
padding: 0 !important;
Thanks!
I put the code -using FTP client - into templates/jp-gusto/css/custom.css, but nothing happens. (the permissions are ok, 755)
I try to put the code into the template settings, using administrator area of the site (where we add the google analytics code, p.e.) and I see the code at the footer in home page.
Regards,
Jo
Regards,
Jo
by griffin
1.) Disbale the "Always compile LESS", see image below
2.) Check the css/custom.css file, because it is not available
Your site > right click > show source > click the custom.css file
Attachment Screenshot_5-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19.jpg not found
