Roksprocket and Joomla 4
- raziel1973
- Junior Boarder
Goodmorning.
On my web site I have Roksprocket extentions. And I don't know if it will be compatible with Joomla 4.
Do you have any alternate showcases extansion?
thank you
Tony
thank you
Tony
by raziel1973
- Thank you received: 1740
Roksprocket will not be compatible with Joomla 4 anymore
For our Joomla 3 and 4 Astroid Themes we have build our own Modules to be independant.
www.theme-point.com/uikit3-extensions.html
But these modules are working not with Warp 7 Themes, because we are using the newest Uikit 3.
For a showcae I would use the Portfolio oder the slider
demo.joomlaplates.com/uikit/portfolio/uikit-3-portfolio.html
- raziel1973
- Junior Boarder
The samples are good.
is it easy to use like spocketrocket or as shortcodes?
In any cases when Joomla 4 will be available for download do I have to change my template too, correct?
Biz is not compatible with Joomla 4. So I have to chose compatible one you have and also after upgraded Joomla I need to create all media modules that I already have created with Roksprocket but this time with uikit-3?
by raziel1973
yes you need to change the theme in Joomla 4.
We are on the way to compile all themes to a better and newer framework.
But in this case you have rebuild your rocksprocket media, modules and something else.
But ...wait at first for Joomla 4 stable and 6 months later.. take a look again
- raziel1973
- Junior Boarder
Many thanks.
I will wait.
Best regardss
Tony
I will wait.
Best regardss
Tony
by raziel1973
