[SOLVED] mailform not working
- Magicnagel
hello,
have a form overhere www.anjanoordmans.com/contact
Does not work.
Did a test mail with joomla mailer phpmail onder global config-server
Checked the mail server at the host, test mail worked
Did it again with the form does not work.
any ideas ?
Does not work.
any ideas ?
by Magicnagel
very sorry but I dont know.
And finally it has nothing todo with the Template. The form is based on Joomla system.
- Magicnagel
Thanks no problem, used another form... works now...
The form that comes with the template does not use there update function and missing links, so they banned it for now.
Great template by the way, keep up doing the good work
Last Edit:5 years 2 weeks ago
by Magicnagel
Last edit: 5 years 2 weeks ago by Magicnagel.
- Magicnagel
