[SOLVED] Override with shortcodes showcase
Hi there
first of all Thank you for the help.
I trying to follow the helps on shortcodes web site to do the override:
But in my case I need to override the file Showcase and my css folder is located here: plugins/system/bdthemes_shortcodes/shortcodes/showcase
But when I using the broswer to analyze the page where I have my showcase I can see the file to edit is another one:
plugins/system/bdthemes_shortcodes/css/cubeportfolio.min.css
So I copied the file suggested in this folder:
but ddn't workes. More I tried with the other one, but nothing, its' continue to not cahnge what I edited.
Any Help?
Thanks
Tony
The instructions:
Suppose, We need to override css of “Heading” shortcode. Let see: how do I override it…
Go “\plugins\system\bdthemes_shortcodes\shortcodes\heading” location.
Copy “css” folder.
Go “\templates\shortcode(Your default Template)\html\plg_bdthemes_shortcodes\shortcodes\heading”. If not exist, create these folder.
Paste “css” folder here.
Edit “heading.css” as you need.
Any Help?
Thanks
Tony
Last Edit:5 years 6 months ago
by nohart
Last edit: 5 years 6 months ago by nohart.
I figure out where I need to copy the css files. may I can help somebody else. The folder is /templates/jp-time/html/plg_bdthemes_shortcodes/shortcodes/css
Thank you
Tony
Thank you
Tony
by nohart
Replied by joomlaplates on topic [SOLVED] Override with shortcodes showcase
Posted 5 years 6 months ago #28785
