[SOLVED] astroid layout and updating to higher templateversion
Last time i did an update on a joomla template and after that when i went to astroid i discovered the astroid layout was empty.
Question:
what do i have to do with astroid layout before you install the higher template version
Replied by WM-Loose on topic astroid layout and updating to higher templateversion
Posted 6 months 2 weeks ago #36478
Look in the template options unter preset.Go to Presets and save your settings. Then download the preset (locally). You can then always import and load this preset in the reverse way.
Replied by solcersoldesign on topic astroid layout and updating to higher templateversion
Posted 6 months 2 weeks ago #36479
see attachement. is this under the layout or under bootstrap where you have to save it
Posted 6 months 2 weeks ago #36480
klick on load default
Posted 6 months 2 weeks ago #36481
load default is not clickable. it does not have a default yet. do i have to click on the purple button to save the whole layout in which i am working and give it a name?
Posted 6 months 2 weeks ago #36482
extra quetion: i see that on almoast every option which you choose at the left side you see you can load a default or select preset. do you have to this om every item or when you save a layout as fedault everything is in it allready?
