Please post only question belong to the topic > pre sales. All support questions will be deleted.
[SOLVED] Color title accordion module
- WB-Autoservice
I use Tp-work template &
Joomla 4
Hello I want to chage the color, size and Bold from the Header and content from the Ulkit 3 Accordion. But can't find the right place to do so. In the module I can change a few things but not enough.
Can anyone give advice?
Thanks in advance,
Hennie
Joomla 4
Thanks in advance,
Hennie
- WB-Autoservice
Thank you for your reply, the URL is
www.cambra.nl/verkoop
The color I'm not sure , needs testing. As it is now the white in the grey, it is not it. The text needs slightly bigger and bold and preferably orange.
Hennie
Hennie
Replied by WM-Loose on topic [SOLVED] Color title accordion module
Posted 1 year 5 months ago #35901
I don't understand what the problem is. You can adjust the colors and font size in the module.
See screenshot:
Info:
www.joomlaplates.de/uikit-3-dokumentatio...kit-3-accordion.html
See screenshot:
Info:
Last Edit:1 year 4 months ago
Last edit: 1 year 4 months ago by WM-Loose.
