RTL Problem
Replied by farzalid on topic RTL Problem
Posted 9 years 4 months ago #17570
Hello again,
I check the template settings and compression look disable there.
The Gzip settings is disable too.
Is that any other setting I must check to do it?
Thanks for your time.
Replied by joomlaplates on topic RTL Problem
Posted 9 years 4 months ago #17572
sorry I dont know your Joomla!!
I think you have a compression enabled, maybe any plugin or anything else!
