RTL Problem
RTL Problem was created by farzalid
Posted 9 years 5 months ago #17490
I try to use template in RTL mode and menus are under articles.
here is the link:
learnstudio.ir/hello/
Replied by joomlaplates on topic RTL Problem
Posted 9 years 5 months ago #17491
please add this code to your css/custom.css
#jp-right {
margin-right: 240px !important;
margin-left:0 !important;
.uk-dropdown-navbar {
right: 240px;
BTW, this theme need some css cutomizing to be the right one for RTL language.
Last Edit:9 years 5 months ago by joomlaplates
Last edit: 9 years 5 months ago by joomlaplates.
Replied by farzalid on topic RTL Problem
Posted 9 years 5 months ago #17561
I add the codes in custom.css file in css folder but not fixed yet.
Posted 9 years 5 months ago #17564
When a site is on development you have to disable all compression and cache tools!!
Please clean your cache and try it again
Posted 9 years 5 months ago #17566
If you look at the site the main part of website is under the menu.
Check the live site at : learnstudio.ir/hello/
I use the clean cache tools too.
Posted 9 years 4 months ago #17568
as I told you before, please disable the compression.
See image attached > Always compressed css files and scripts!
Attachment compressd.jpg not found
And then please add the code below to your css/custom.css
#jp-right {
right: 240px;
Last Edit:9 years 4 months ago by joomlaplates
Last edit: 9 years 4 months ago by joomlaplates.
