[SOLVED] Slideshow Problem
- mavre.creative@gmail.com
Good morning,
I'm trying to create a slideshow, but instead of a slideshow, the photos appear one below the other on the home screen.
Furthermore, on the left side of the images appears a black dot.
I've attached a screenshot.
How can I fix this?
Thank you so much,
Elena
How can I fix this?
Thank you so much,
Elena
Last Edit:1 year 1 month ago
by mavre.creative@gmail.com
Last edit: 1 year 1 month ago by mavre.creative@gmail.com.
This is because you haven't installed and activated the UIKIT 4 plugin. Without the plugin, the UIKIT modules won't work. If you still have the old UIKIT 3 plugin installed, you'll need to uninstall it, as both UIKIT plugins won't work together.
The following user(s) said Thank You: mavre.creative@gmail.com
Replied by mavre.creative@gmail.com on topic [SOLVED] Slideshow Problem
Posted 1 year 4 weeks ago #36086
Thanks! The plugin was installed but not enabled. I fixed it, thanks a lot!
Last Edit:1 year 4 weeks ago
Last edit: 1 year 4 weeks ago by WM-Loose.
