[SOLVED] Medical + GRID module problem
  • Timer
Medical + GRID module problem was created by Timer
Posted 4 months 3 weeks ago #36605
Hello!
Im using on my site a Medical template and a U3 grid module. I have a problem with Grid, in mobile view. Regardless of what I set in the module’s mobile view settings, the mobile display shows the same content as on a desktop computer. It displays the content in a 3/4-column layout, which means that images and titles no longer appear properly, and if there is text content as well, the mobile view completely breaks down. What could be the problem? Thank you for your reply!
Regards, Timer
by Timer
Replied by WM-Loose on topic Medical + GRID module problem
Posted 4 months 3 weeks ago #36606
Unfortunately, without a link to the affected website, this cannot be analyzed. Please provide the URL.
The following user(s) said Thank You: Timer
  • Timer
Replied by Timer on topic Medical + GRID module problem
Posted 4 months 3 weeks ago #36608
Hello!
Thank you for your reply! The affected website is: ravaikft.hu (this is a demo site now)
by Timer
Posted 4 months 3 weeks ago #36609
OK Login-Data Backend (please an sent it to:  zugangsdaten@joomlaplates.de).
Create a backup of your site beforehand.
But first: set tablet on 100% and test ist again.
Last Edit:4 months 3 weeks ago by WM-Loose
Last edit: 4 months 3 weeks ago by WM-Loose.
  • Timer
Replied by Timer on topic [SOLVED] Medical + GRID module problem
Posted 4 months 3 weeks ago #36610
Thank you for your suggestion! The tablet's value setting was ineffective, but if I modified the "Default" value do the trick. I don't know  why, but it works.
Thanks again!
Last Edit:4 months 3 weeks ago by Timer
