[SOLVED] Fehlermeldung: Call to a member function getPositions() on null
Fehlermeldung: Call to a member function getPositions() on null was created by Kapo
Posted 1 month 12 hours ago #34567
Hallo liebe Forumsteilnehmer,
ich habe dieses und andere Foren durchforstet, aber leider keine Lösung gefunden...
Beim Klick auf „Edit“ im Frontend erscheint folgende Meldung:
0
Fehlerausgabe:
Warning: Trying to access array offset on value of type bool in [...]/webseiten/tis/libraries/astroid/framework/library/astroid/Helper/Head.php on line 40
Debug:
Call Stack
Vielleicht weiß jemand eine Lösung?
Merci
Andreas
0
Fehlerausgabe:
Debug:
Call Stack
# | Function | Location |
1 | () | JROOT/templates/tp_hotel/html/com_config/modules/default_positions.php:11 |
2 | include() | JROOT/libraries/src/MVC/View/HtmlView.php:416 |
3 | Joomla\CMS\MVC\View\HtmlView->loadTemplate() | JROOT/templates/tp_hotel/html/com_config/modules/default.php:108 |
4 | include() | JROOT/libraries/src/MVC/View/HtmlView.php:416 |
5 | Joomla\CMS\MVC\View\HtmlView->loadTemplate() | JROOT/libraries/src/MVC/View/HtmlView.php:204 |
6 | Joomla\CMS\MVC\View\HtmlView->display() | JROOT/components/com_config/src/View/Modules/HtmlView.php:85 |
7 | Joomla\Component\Config\Site\View\Modules\HtmlView->display() | JROOT/libraries/src/MVC/Controller/BaseController.php:697 |
8 | Joomla\CMS\MVC\Controller\BaseController->display() | JROOT/libraries/src/MVC/Controller/BaseController.php:730 |
9 | Joomla\CMS\MVC\Controller\BaseController->execute() | JROOT/libraries/src/Dispatcher/ComponentDispatcher.php:143 |
10 | Joomla\CMS\Dispatcher\ComponentDispatcher->dispatch() | JROOT/libraries/src/Component/ComponentHelper.php:361 |
11 | Joomla\CMS\Component\ComponentHelper::renderComponent() | JROOT/libraries/src/Application/SiteApplication.php:218 |
12 | Joomla\CMS\Application\SiteApplication->dispatch() | JROOT/libraries/src/Application/SiteApplication.php:261 |
13 | Joomla\CMS\Application\SiteApplication->doExecute() | JROOT/libraries/src/Application/CMSApplication.php:306 |
14 | Joomla\CMS\Application\CMSApplication->execute() | JROOT/includes/app.php:58 |
15 | require_once() | JROOT/index.php:32 |
Merci
Andreas
by Kapo
Replied by WM-Loose on topic Fehlermeldung: Call to a member function getPositions() on null
Posted 1 month 5 hours ago #34568
Hier fehlen alle Angaben: Joomla und PHP-Version? Template und Framework-Version?
Replied by Kapo on topic Fehlermeldung: Call to a member function getPositions() on null
Posted 1 month 3 hours ago #34569
Ja, sorry....
Joomla 5 / PHP 8.2 / tp_hotel: 1.3.17 / Framework: 3.0.12
by Kapo
- Thank you received: 1713
Replied by joomlaplates on topic Fehlermeldung: Call to a member function getPositions() on null
Posted 1 month 2 hours ago #34570
Bei welchem Modul kommt der Fehler? Bei jedem Modul?
Welchen Editor benutzen sie?
Posted 1 month 1 hour ago #34571
- Editor ist egal... TinyMCE, JCE, keinen ... immer die gleiche Meldung
- bei jedem Modul:
- beim Versuch einen Beitrag zu bearbeiten kommt folgende Meldung:
500
behavior::tabstate not found.
übrigens läuft die site zu Testzwecken auch auf meinem lokalen Apache sowie auf dem Server des Providers (offline) - bei beiden das gleiche Problem!
- bei jedem Modul:
500
by Kapo
Posted 1 month 25 minutes ago #34572
Das hat nichts mit dem Template oder dem Framework zu tun.
Hier könnte eine nicht J5 oder PHP8 geeignete Erweiterung oder Plugin die Ursache sein.
Eine Neuinstallation schließe ich mal aus und vermute hier wurde eine J3 Seite nach J4 und dann nach J5 migriert!
